2001 Celica GT Running Rough - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-20-2009, 03:44 PM   #1 (permalink)
View Uniquecustomstc's Photo Gallery
We recently purchased a 2001 Celica GT with a blown engine. We have replaced several engines in these Celica's before and had no problem. This Celica has DC headers, Injen intake, and Wesco pistons on it. We put the engine in and turned it over, the only way it would actually start was to give it some throttle while turning it over. It will start and run like absolute **** (shaking the car from such a rough idle). If you rev it up, it will cut out, spit and sputter, then once it manages to get to higher RPM's it runs pretty good, but only at high RPM's. Once you let off the gas it runs rough again. So we figured the vacuum lines could be hooked up incorrectly from thr past owner, and we switched a few around, and it made no difference on the idle. This is when we noticed one of the connectors (according to ALLDATA is an intake sensor) has nothing to plug into because of the aftermarket intake. So we kept the car running, revving it up and giving it time to adjust, it seems to get a bit better but is not running like it should be. (We have replaced the injectors, fuel rail, coil packs, new plugs, and a new air filter.) So, does anyone have any idea what this could be?
Here are a couple pics of my intake area....
Uniquecustomstc is offline   Reply With Quote
Old 03-25-2009, 03:33 PM   #2 (permalink)
Does anyone have any ideas on this??
Old 03-25-2009, 04:21 PM   #3 (permalink)
View concealer404's Photo Gallery
Yep.
Plug that sensor in. Although why that would make it hard to start seems a little weird.
But if that's the IAT, which i think it is, that'll definitely cause your other problems once it's running.
1993 Celica GT Coupe (sold w/ 218k miles)
1992 Celica GT Hatch (The new $600 hotness.)
1993 Escort GT ( i have a thing for GTs.) POWERED BY MAZDA B-SERIES
concealer404 is offline   Reply With Quote
Old 03-26-2009, 05:36 PM   #4 (permalink)
View bionictony's Photo Gallery
try to find the stock airbox and take the injen intake out. find the plug where that thing goes to. also try cleaning the MAF sensor that's attached to the injen intake with 2 screws.
bionictony is offline   Reply With Quote
