trans fluid dipstick - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-16-2009, 07:43 AM   #1 (permalink)
new celica owner
View ximporttunerx's Photo Gallery
Gen5 trans fluid dipstick
i want to change my trans fluid in my celi but i cant find the dipstick for one and i have no idea where to start changing it at any help please?
ximporttunerx is offline   Reply With Quote
Old 04-16-2009, 02:41 PM   #2 (permalink)
View toyomoho's Photo Gallery
The trans may have drain and fill plugs on the side.
The drain and fill proceedure would be differant and more involved. This requires draining then over filling the trans. Heating the fluid up to a certain temp by starting the engine then draining the excess.
Old 04-16-2009, 02:58 PM   #3 (permalink)
Rick89GTS's Avatar
View Rick89GTS's Photo Gallery
Your car is a '91 GT 5 speed. On a manual tranny, there is no distick. Only auto trannys have the dipstick.
ST162 manual tranny below, the ST182/5SFE tranny will be very similar.
IIRC, they are 22mm or 24mm bolts. Drain it all out and then refill until it flows out of the fill hole - that will be the proper oil level. Car must be level for this.
Rick89GTS is offline   Reply With Quote
Old 04-16-2009, 06:24 PM   #4 (permalink)
Rick89GTS's Avatar
To refill, you can use the funnel and vinyl tubing gravity method. I prefer the suction gun. Pretty easy to just pump it in:
