5afe question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-12-2009, 04:15 PM   #1 (permalink)
View Danedog's Photo Gallery
5afe question
ll Explain The Situation
92 Celica ST
5afe Engine Swap (JDM)
I have a 5afe (NOT 5sfe) it is a 1.5l replacement for the 1.6 4afe... Engine ran great... low oil... spun bearing... so I dropped the Oil pan... number 3 Connecting rod is the culprit... and it's NOT the same color as the rest of the Connecting rods... Crank Specs seem to be the same as the 4afe... and the engine has good, even compression... the crank specs out fine...
I was told the 4afe-5afe use the same bearings... replaced all crank and rod bearings... Still knocks and keeps chewing the number 3 rod bearing... I believe the rod and cap are tweaked... so... here comes the questions...
Are the 4afe Connecting rods the same as the 5afe?... I already know the studs are different threading between the two but they are same Diameter studs and length...
So basically is the 5afe de-stroked on the crank? de-stroked on the rod? or does it use smaller pistons to lower to a 1.5l instead of the 4afe 1.6?
any knowledge would be a great help...
anyone know what car a 5afe would come in stock?
Thanks again!
Danedog is offline   Reply With Quote
Old 05-13-2009, 05:23 PM   #2 (permalink)
Gameroom cash: $147537
http://www.toysport.com/Technical%20...spec_sheet.htm
Old 05-13-2009, 06:45 PM   #3 (permalink)
so same stroke, i know the cranks are the same... how do i know if a so the length and crank end are the same... what about the piston pin size?
thanks pineapple
Old 05-24-2009, 11:11 AM   #4 (permalink)
No body knows if a early style 5afe has an 18 or 20 mm pin?
Old 05-04-2010, 03:08 PM   #5 (permalink)
Wow old post... The 4afe and 5afe connecting rods are the same for anyone seeking this advice
