5SFE cam timing. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-16-2009, 11:04 PM   #1 (permalink)
View Twintrucks's Photo Gallery
5SFE cam timing.
Well folks I have been looking in here for around an hour now trying to find pics of this cam setup. My Hanyes book is just driving me crazy. I rebuilt my engine over the past year. I thought all was good till it would not start. Checked my belt timing was off just a tad fixed it but still no fire in the hole. So here I am back looking at cam timing again. Haynes says line up the dots, shows pics of ref and timing dots. They do not mention the other dots on both gears. If I have these set up correct it should be the 2 sets of single dots with the ref dots up and timing dots lined up dot to dot. Any help here would be great.
Alan
Twintrucks is offline   Reply With Quote
Old 05-19-2009, 09:28 AM   #2 (permalink)
Gameroom cash: $147537
See if this helps:
Old 05-19-2009, 06:58 PM   #3 (permalink)
bajachris88's Avatar
View bajachris88's Photo Gallery
Even with bad cam timing, you should get some form of firing. Whether it be a back fire or kick back. you getting any of that?
BTW, i think the haynes manual for the celica is an absolute pile of s@%t! That book had me sooo fired up on too many occasions.
__________________________________________________ ________
Chris Leete.
Ride: Australian 5sge powered 1990 st184r,
Co-founder of exclusive ELANORA CELICA CLUB AUST.
Current members: st184r, st162, ta23, ra28.
bajachris88 is offline   Reply With Quote
Old 05-19-2009, 07:16 PM   #4 (permalink)
Thanks Pineapple, same pic that is in the haynes book. Just means i had the cam in correct. LOL
I don't get any back fire, I can not hear the fuel pump run when teh key turns either. But I can jump the test connector and get it to run.
Thanks for the help guys will go back out and do more trouble shooting. Car was a cheap pick up so I have no real cash into it just yet, Other than the engine rebuild.
Old 05-19-2009, 10:49 PM   #5 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
You'll get it going, the cam gear isn't that hard to line-up. When I swapped the gasket/o-ring on my oil pump (and crank seal, etc) recently, I fudged the t-belt ever so slightly--it skipped half a dozen teeth. I know, I know, dumbass...
I was easily able to line-up the crank and cam again, though. Got it running in no time. Follow the fuel pump idea and I think you'll have the real problem solved...
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
