1: pop off the shift knob
2: the main console where the deck sits in, its all clipped in. take a screwdriver and lightly pry the corners off. even using your fingers will work.
3: take off the shift boot, i cant remember if that has to come off before the console does. (the plastic frame that covers the whole middle of the lower dash including heating and stereo)
4: unscrew the 4 screws holding the main unit in
5: (mine came in a big bundle with 2 metal pieces attached to the sides to hold it in) so if this is your case just take out the stock deck, and put in the new one, bolt it back on and it looks as if it were a perfect fit. If not you will need to buy a mounting kit.
