No power to coil side of efi relay or fuel pump(wheres the fuel pump relay???)
Its a 93 celica st that has the 5afe replacement for the 4afe(straight swap)I swapped the engine but no starting for me. Never thought it was right changed the distributor 3 times. Noe if i jump the switch side of the relay it will run on starting fluid. but the fuel pump wont come on. The fuel pump is good the engine was just running previoulsy with 3 holes in the block. Did the self diagnosis via engine light and it says nothing is wrong, no code at all. Im runnin on low, since Friday with it and i know it has to be something small. ive studied the haynes manual but it sucks and is not a complete wiring diagram which it even teloles you in the book they dont provide all diagrams.
