1997 3s-ge engine in 1993 celica - running problems
hi guys, my name is adam and i'm new here.
i have a problem hopefully someone can help with - i have a 1993 5th gen celica gt-r 2.0 16v 3s-ge (gen2 motor) which i have replaced for a 1997 3s-ge (gen3 motor) but now the car runs really lumpy with no power... on tick over its fine but when i pull away and try to drive it it is really sluggish and actually sounds like a subaru impreza boxer engine!!
does anyone know whether the 1993 ecu will work with the 1997 motor or will i need the ecu from the newer engine?
also that little pipe that sucks air into the throttle body, the idle control valve i think, is sucking air in like crazy - i mean REALLY sucking air in with alot of force and i'm sure the old engine didnt suck as much as that!
could this be a vacuum issue as the engines seem to have slightly different vacuum systems, i think i'v matched them up correctly.
i have changed the plugs and leads and it hasn't made a difference.
has anyone done a gen2 3s-ge to a gen3 3s-ge swap successfully?
any ideas anyone??? please help!
thanks in advance
adam
