The fuse protects the circuitry by blowing first instead of causing a fire or making the whole circuit too hot until something fails which is supposed to be the fuse so you really don't want to use a different size fuse, even though it will work. Check for bare wires and repair it. Bare wires blow fuses and so do bad sockets. If the positive of your battery touches the negative or ground without resistance or a component in between, then infinite current is generated until something blows which doesn't take long. If you put a piece of wire, a penny or a bigger fuse in instead of the correct fuse then there is nothing to stop the infinite current and the weakest point in the circuit will catch fire. The weakest point is supposed to be the fuse and if you put a stronger one in that can handle more amps then it can cause problems, not solve them. There is a wire with a cut or worn out side and the inside wire is touching some metal somewhere making the fuse blow or could be the socket. Check a manual for the tail light wiring diagram or just remove the tail lights and follow the wire after checking the socket. You might need a multimeter to help find the short. What kind of car do you have?
91 Celica GT Coupe
Knowledge builds confidence.
