now the question is, how difficult is it to change the drive shafts and are there any special things i need to mark before i remove any parts?
Depends on if you have the space and tools necessary. You will need a set of wrenches and sockets in 12,14,17 and 19mm, the 30mm axlenut socket, and a flexbar (Or a piece of pipe) long enough. (those axleshafts are torqued to 200 ft/lb, so you need the leverage to overcome it - wrench it off while the wheel is on the ground) a torque wrench would be nice, but since you are on a budget, borrowing one or just making it "nice and tight" should be good enough.
Find some good solid blocking to support the car. remember you have to get right under the vehicle to pop the inner CV joints out, and that's your face under some 1500lb of metal. Saftey First!
Before you start, it would be worth it to look for leaks coming from the driveshaft seals, as you have the chance to replace them while the shafts are out.
The procedure is like what robbo said. the strut/wheel bearing has to move aside to get the front end of the shaft out, and the way to do that is to undo the three bolts on the ball joint. after that, other than the little carrier bearing, the removal is pretty straightforward. Popping the axleshafts out of the transmission will be a little frustrating (Prying is all but impossible!), and I find wacking it with some wood and a hammer is the way to go. Remember to not be under the transmisson when you pull the shaft out, and have a pan ready.
I would set aside half a day to do a job like this. I estimate on my first time I did this it took me three hours to get both shafts out and replaced (Not counting buttoning it back together and cleaning up).
For driveshafts, I got mine from NAPA. Corolla shafts were around $150 each with a core deposit.
