5sfe 91 celica will not start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-01-2009, 09:09 PM   #1 (permalink)
View bourgason's Photo Gallery
Canada 5sfe 91 celica will not start
Okay so here is my story. I have swapped out a blown 5sfe for another 5sfe from a car that i know for sure runs. I have everything hooked up but it wont seem to start. I have made sure that the fuel pump is fine and i am getting fuel all the way to the fuel rail. I have check that distributor and is it turning so the timing belt is still working. The plug wires are good and the sparkplugs are working as well. I have bridged the te1 and e1 connector and the ecu is showing no codes just a steady flashing check engine light. I have checked all of the fuses and they all seem to be fine. I have tried to crank the engine and it just wont start. pulled the plugs to see if i was getting any fuel around the plugs and they are bone dry.
So i have come to the conclusion that it has to be a problem with the injectors not firing. So does anyone have ideas on how to figure out if it is the injectors or something else.
Oh and this is a project car so at the moment it has no interior and everything is able to be accessed if needs be.
bourgason is offline   Reply With Quote
Old 08-03-2009, 12:15 AM   #2 (permalink)
Gameroom cash: $147537
Pull cold start injector to see if its working. If not, you're not getting fuel. Check all ground wires to make sure you didn't missed any. I guess you did check for spark while you're cranking?
