Toyota Corolla NO HEAT AT IDLE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-13-2004, 06:21 PM   #1 (permalink)
View FDXMAN's Photo Gallery
I have a 97 corolla that will not put out any heat at idle. It has a new thermostat, i flushed the cooling system twice. You can take the hoses off the heater core and blow thru them relatively easy. I shot the radiator with a heat gun and it is 200 degrees, the heater hoses are not getting hot . Any one else had this problem, kind of leaning towards heater core still partially blocked but it doesnt seem to be. It heats good at higher RPM and then engine does not overheat.
FDXMAN is offline   Reply With Quote
Old 02-14-2004, 12:16 PM   #2 (permalink)
Blane's Avatar
View Blane's Photo Gallery
Toyotas run cool at idle. Mine shoots out loop warm air after 5 minutes of idleing. As long as your tempurature guage is not rising when your heater is blowing cold than that is normal.
Blane is offline   Reply With Quote
Old 02-14-2004, 12:21 PM   #3 (permalink)
not actual size
brink's Avatar
View brink's Photo Gallery
Maybe your heater core is b0rken.
Or it could be something as simple as the control to adjust cabin temperature isn't working, so you're not actually upping the temps when you move the lever/turn the dial.
-- Jonathan W.
http://camry.wanthoney.com
http://fleshy.org.nz/yum/
brink is offline   Reply With Quote
