non starting - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-07-2009, 07:55 AM   #1 (permalink)
View JerryHeat's Photo Gallery
non starting
Good day. I have a 92 GT conv. Here's the prob - car running fine (was) - made several stops - got back in one from one of the stops - engine cranks just fine but does not fire a single time - as if lost complete fire or as if zero gas (there is gas). Where should I start? If it is a fuel problem where might i get fuel system diagram? thank You
JerryHeat is offline   Reply With Quote
Old 08-16-2009, 03:01 AM   #2 (permalink)
walter34's Avatar
View walter34's Photo Gallery
Fuel filter may be pluged. Also take the air cleaner off and see when someone is cranking it over to see if its getting fuel. ie; smell, see. Also check to see if you have spark from one of your wires.
walter34 is offline   Reply With Quote
Old 08-17-2009, 10:49 AM   #3 (permalink)
Thank You
Old 08-17-2009, 12:27 PM   #4 (permalink)
View toyotadriftr's Photo Gallery
Could it be your camshaft position sensor? Had a car do the same thing just crank and crank and was told to replace the sensor and it worked
toyotadriftr is offline   Reply With Quote
Old 08-17-2009, 01:50 PM   #5 (permalink)
Thanks for the reply - as far as I know it could be the muffler bearings (smile). What I found peculiar is that pre - this incident I never had 'any' issue. No acting like it was running out of gas - no mis-firing. Get out of the car for dinner - get back in and zero firing. thanks again
