91 GT low on power after timing belt replaced
A friend has a 91 Celica GT (135k on a 5sfe and automatic) that had the timing belt break on his way home from work. We replaced the belt, idler and tensioner pulleys and water pump. It started right up, but the engine seems to be down on power and has a stumble off of idle. On the test ride it struggles to get the car moving (needs lots of throttle) and starts to feel better about 3k and then upshifts hard and with the revs down it's back to not a lot of power. I've removed the top timing belt cover to verify the cam gear alignment (a PITA since you can't do it visually, so I used a nail to align the cam gear hole and the dimple in the head) and all seems to be OK there. A leakdown test gave about 18% loss consistently on all 4 cylinders, so I don't think there's any valve damage. Any ideas what to check next? TIA,
Rob
