1985 22RE Turbo Build HELP ME OUT - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-20-2009, 09:55 PM   #1 (permalink)
Full Throttle Fabrication
View DeadEyes's Photo Gallery
hey hows it goin? so Im really diggin my celica. rwd is real fun! my speedo dont work tho. everything else in the gauge cluster works just not the speedo. but anyways Im gonna rebuild the stock 22re since the speedo died at 242k and I dont know how many miles its got. but anyways Im gonna be pulling the motor out and completely rebuilding it. from the pan up. but I wana boost it. Got a TurboNetics T3/T4 but I need a manifold. also looking for a rebuild kit for the motor with the right head gasket and forged pistons. Will the pistons from the 22ret fit my 22re block? also what would be recommended for the intake and cam and that stuff? I know what parts I need to buy but I dont know what sites sell them. Im used to building small block chevys...never done a toyota motor. and I know im gonna get bashed for my idea of wanting to build a 22r. but they rip for a little motor like that...my town is small and theres bunch of potholes. no place to open it up like yall guys do. so the 22r is plenty if built right and enough boost. im looking to run between 10-15psi depending on what im doing. yes full intercooler as well. I need a manifold tho so if anyone has one please let me know.
DeadEyes is offline   Reply With Quote
Old 08-20-2009, 10:39 PM   #2 (permalink)
JoeBowHunter's Avatar
View JoeBowHunter's Photo Gallery
ebay sells alot of things that your looking for, both used and new of coarse, but just give it a go. um for the speedo, you can probly get a new cable for it, and if you want to get all that psi youre going to have to do a bit of work...hope i can help. I dont know alot but i hope im not waisting your time=)
JoeBowHunter is offline   Reply With Quote
Old 08-21-2009, 01:09 AM   #3 (permalink)
well I expect to do alot of work. no doubt. I already found my engine rebuild kit from IPP. ImportPerformanceParts.com I was looking at the ultra engine kit. coimes with everything i need to rebuild the engine including pistons for the 22ret. also comes with an oil pump,water pump and timing kit. what kind of cam should I look at if I am looking to make between 8-14lbs. also how much will the stock replacement pistons,rods?
Old 08-21-2009, 06:15 AM   #4 (permalink)
RA28 + MX73
Gameroom cash: $107620
View stepho's Photo Gallery
Browse around at http://www.lcengineering.com/
You might not buy there but it will give you an idea of what you need.
- Stepho
stepho is offline   Reply With Quote
Old 08-25-2009, 02:48 PM   #5 (permalink)
LocDown's Avatar
View LocDown's Photo Gallery
Have you checked your speedo drive gear in the tranny? It might have slipped out of place.
2001 PreRunner DblCab V6
Line-X, Allpro Sliders, Lightforce 170 HID
Toytec Coilovers and Bilstein 5100 rear with Toytec AAL
15x8 ProComp Streetlock, 33x12.5x15 BFG AT
LocDown is offline   Reply With Quote
Old 08-26-2009, 01:50 AM   #6 (permalink)
i havent done that yet. my fuel pump just died...at the gas pump! so i dropped the tank and so on. and hard wired the fuel pump to the battery for a sec to see if it works. and it does so i did all that for nothing...but thats 135 i dont have to worry about. so now i gotta figure out whats goin on. all fuses are good...but computer and relays im not sure of.
Old 08-26-2009, 08:59 AM   #7 (permalink)
RA28 + MX73
Sounds like either the fuel relay or the oil sender has gone.
The oil sender provides the ground for the fuel relay (a safety feature which automatically disables the fuel pump after an accident).
Buy the Haynes Celica RWD manual - it covers this subjects quite well.
Where the speedo cable screws into the back of the gauge cluster sometimes comes loose.
Tighten it up.
A bit tricky because you have to reach behind the dash and you can't see where your hand is going.
- Stepho
Old 08-26-2009, 11:01 PM   #8 (permalink)
well i got the car home today. I just hardwired the fuel pump temporarily till I can sort things out. I got a 2200$ check coming in the mail...time to start building!
