89 celica speedo cable leak--help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-17-2004, 02:06 PM   #1 (permalink)
View tspieker's Photo Gallery
I have an 89 celica gt with cruise control. My speedometer cable started leaking a lot of oil. At first I thought it was just degraded grease oozing out but it keeps coming. I also replaced the upper portion (2-piece) of the cable thinking the new packed grease cable would stop any oil movement up the cable. I didn't make it 20 miles before all the grease had been pushed out of the cable and oil is now running out. It also does not look like transmission fluid as I would expect but could just be discolored from moving up the greasy cable. It is more of a dark carmel color. Anyone know what will fix the problem. I am concerned that just replacing both portions of the cable won't work if there is a seal I don't know about that keeps the transmission fluid pressure from pushing the grease out. Is the seal in the bottom portion of the cable? Or is there another seal/component that needs replacing. I have the two cable portions ordered (guess the previous upper portion is waste since all the grease is pushed out--????).
any help appreciated -- do you think only replacing the lower portion will work
tspieker is offline   Reply With Quote
Old 05-11-2004, 09:45 PM   #2 (permalink)
View shmuggums90's Photo Gallery
You need a speedometer driven gear seal, looks like a valve stem seal and fits into speedometer driver gear housing. Probably less than $10 from local dealership...
shmuggums90 is offline   Reply With Quote
