Excessive idle at startup - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-17-2004, 04:46 PM   #1 (permalink)
View lloydjv's Photo Gallery
Has anyone experienced 2100 RPM at cold start up? After 4 to 5 minutes, the idle slowly begins to return to normal. I have had this car for almost a year, and this has been a problem since day one. In the meantime, we have replaced the block, timing belt, tps, and coolant temp sensor. The vehicle also vibrates at normal idle with timing set at 10 degrees BTDC. I am perplexed.
lloydjv is offline   Reply With Quote
Old 02-17-2004, 06:12 PM   #2 (permalink)
camrys blow off too!
View silverstreakin's Photo Gallery
i had a problem like that with my 88 celica 3s-fe. the idle screw was totally dicked and it needed a tune up. after that it was fine though
93 toyota mark II tourer V
1jz-gte twin turbo goodness!
93 toyota scepter turbo stored back in the states!
*in loving memory rapeacivic*
silverstreakin is offline   Reply With Quote
Old 02-18-2004, 01:26 PM   #3 (permalink)
View celica kid's Photo Gallery
me 5sfe did the same thing..not quite 2100...maybe like 1800 for about a minute but my engine shakes at idle...i just did a head job and replaced my vacuum hoses wires plugs, gaskets and cleaned my fuel injectors. am almost done i should finish putting it all back together today or tom. and i will let you know if it fixed anything
Cameron Crooks™
celica kid is offline   Reply With Quote
Old 02-18-2004, 06:27 PM   #4 (permalink)
Cool, deal, guys. I actually went out to Autozone and bought a bottle of RXP and used it. Seems to have calmed things down a bit. A little more get up and go, too. I took the advice of a radio car guy in the area.
Old 02-19-2004, 01:21 PM   #5 (permalink)
is that fuel injector cleaner or something of that nature?
Cameron Crooks™
Old 02-19-2004, 06:47 PM   #6 (permalink)
Go to the website below and you can read up on some of the scientific data and test results.
http://rxp.com/master.htm
Old 02-20-2004, 12:03 PM   #7 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
i think thats just normal.....most cars will have a cold start idle function....keeps rpms up until engine is up to normal operating temps....i got rid of it though...no real need for it....i just let the car warm up on its own and dont go anywhere near into boost until shes up to temp.....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 01-27-2008, 12:51 AM   #8 (permalink)
View Bio_Hazard2k8's Photo Gallery
my 85 GT does the samething but it takes like 2-5 miles of driving to warm-up and stop the 2k+ cold idle, I'm not worried as it goes to normal after a while
Bio_Hazard2k8 is offline   Reply With Quote
