4a-ge head into 4a-fe block...is this possible??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-19-2009, 12:29 PM   #1 (permalink)
View tt89mw's Photo Gallery
I have a 90 celica ST with a stock 4A-FE engine. and my cousin has 4a-ge parts that he is willing to sell to me.
i need to see if the silvertop 4A-GE head would fit on the FE block. i am not sure cuz the head has VVT and its got 20v, while my celica has 16v. so i know extra wiring would be necessary. but I need to see if this can happen...any advice?
tt89mw is offline   Reply With Quote
Old 09-19-2009, 11:56 PM   #2 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
yes an no. yes the blocks are the same but IIRC some of it will not match up. this has been touched on a bunch over in the corolla section.
When it comes to wiring think of it like the wiring depends upon the head so yes you will need a wiring harness and ecu. honestly its easier to swap the whole engine before you'd put the head on your block. plus you wouldn't get less performance than a stock silvertop due to lower compression ratios in the 4af than the silvertop.
Although it sounds like a good idea, it would be much easier to swap the whole thing.
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 09-21-2009, 09:24 AM   #3 (permalink)
Wonderbread
4agetercel's Avatar
Gameroom cash: $160040
View 4agetercel's Photo Gallery
swap the whole engine..... you wont be able to run it off the 4afe ecu either
but to answer your question yes the head head itself will bolt up
4agetercel is offline   Reply With Quote
Old 09-21-2009, 07:06 PM   #4 (permalink)
N/A bites
Tercel GTS's Avatar
Bolt up yes. Valve hit pistons that have wrong angles cut for the angle the new valves are sitting at, maybe. Doesn't the 4age come with a forged crank and 4afe cast? Should we get into rod specs too?
Swap the whole engine.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
