The only 6 cylinder engine that will fit without serious surgery or killing the weight bias is the 1G.
Comes in 1G-GTE turbo or 1G-GZE supercharger forms.
The 1UZ-FE fits but requires a fair bit of effort.
Here's my stalled attempt on a TA45 Carina.
http://members.iinet.net.au/~stepho/mods.htm#CarinaV8
A more obvious choice is the 3T-GTE turbo engine.
Drop in replacement for your old 3T-C.
Make sure you get the gearbox because the bellhousing is ultra rare (although the 1G uses a compatible one with the clutch cylinder on the other side).
Or just use an automatic gearbox - common as chips.
160HP stock, 200HP with a bigger turbo, 300HP with serious internal upgrades.
A 4A-GZE supercharged engine can be made to fit but if I remember rightly the distributor hits the firewall (or I might be thinking of the 20 valve).
Convert to a crank angle sensor (needs aftermarket ECU), or add an elbow to the distributor drive or put a recess in the firewall.
The last of the 20 valve 4A-GE's put out similar power.
The 3S-GTE can fit.
Use a bellhousing from the ST141 Corona.
If you have more money you can get a 6 speed sequential gearbox from a JDM Caldina.
The Caldina can also supply a nice 3S-GE.
Can you do me a favour?
The JDM TA63 Carina's that I have brochures for only mention the 3T-GTE GT-T and GT-TR.
I'd like to see the info on the build plate on the firewall in the engine bay so I can add it to my Carina web page.
Thanks.
- Stepho
