The rolling 30 year exemption does not apply to California anymore
in case of high CO failure on the carburated Celica I would probably do the following:
First check the vacuum hoses around the carburetor for proper routing and make sure that they are not collapsed inside; 6 years ago I came across the grossly polluting 87 tercel where 2 out of 3 hoses were connected incorrectly to the ported vacuum switch, causing the engine to run in the "below +4 degrees C' mode.
The air injector pump supplies the air into the exhaust ports when engine is cold and to the catalyst when the engine is on normal operation temperature.
If all hoses are good and properly connected, the next step is checking ported switches.
This car does not have electronic mixture control therefore if all systems are checked out good, looking on the carburetor itself can be the last step;
The choke should open fully when the car is on normal operation temperature; check dual diaphragm choke opener
high float level is probably not an issue, as this will cause poor idle and backfire on accelerationLeaking seal on the acceleration pump and power valve can be issues as well, but this will call for carburetor removal and disassembly. Let me look for carburetor vac hose schematic to be more specific
