what's up w/ this engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2009, 02:08 AM   #1 (permalink)
View musegrlz's Photo Gallery
looking through cl and this came up- 1997 Celica GT, what's up w/ the engine- is that thing a filter, can it be replaced w/ a standard filter? From looking at the photo is there any missing or modified that influence performance, or the way the car will run and sound- I'm not completely familiar w/ what a 94-99 celica engine looks like, is that an ABS pump/box in the lower left corner near the windshield fluid?
musegrlz is offline   Reply With Quote
Old 11-11-2009, 08:44 AM   #2 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
yeah its a housing for an air filter, you could probably just pull a stock airbox if you wanted to go back. Also there's a header. Check the exhaust, if this was mated to the stock exhaust, it likely eliminated the catalytic converter.
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 11-11-2009, 07:58 PM   #3 (permalink)
christine_lives!'s Avatar
View christine_lives!'s Photo Gallery
Mm mmm aerosol painted cover and intake...
The ABS controller is in the lower left with the metal tubing coming from the top. The cruise control box gets moved next to the battery when you have ABS.
You are looking at a 3rd Revolution 5S-FE. Should look similar to below, they have a modified exhaust header without the heat shield. I agree with Rob, they've likely cut out the cat.
christine_lives! is offline   Reply With Quote
Old 11-12-2009, 12:18 AM   #4 (permalink)
6th gen master
View hatchy_gt-s's Photo Gallery
on that engine you dont have to cut ou the cat it is bolted to the manifold and is removed when equiping an ebay header.
aftermarket header
Its not about what the car can do, its all about what the driver can do.
hatchy_gt-s is offline   Reply With Quote
Old 11-12-2009, 06:44 AM   #5 (permalink)
True.
I was just trying to get the OP to cover all his bases. Many of the headers I've seen for this eliminated the cat, but it does look like an ebay header.
Old 11-12-2009, 06:11 PM   #6 (permalink)
thanks for the replies i went to see this car and it was messed up....
