Ring and pinion - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2009, 04:32 PM   #1 (permalink)
TAB2089's Avatar
View TAB2089's Photo Gallery
2nd Generation Ring and pinion
im looking for a 6.5' ring and pinion set for my 2nd gen celica.
anyone know whrere to find a set? a website? anything?
TAB2089 is offline   Reply With Quote
Old 11-17-2009, 06:32 AM   #2 (permalink)
RA28 + MX73
Gameroom cash: $107620
View stepho's Photo Gallery
That should be a 6.7" T series diff.
You will also need to get the same ratio unless you want the top speed / acceleration to be different and the speedometer to be incorrect.
The build plate on the firewall in the engine bay will have a code something like T312 which you can decode here:
http://members.iinet.net.au/~stepho/diff.htm
Most likely it is a 3.308 or 3.358 ratio.
Donor vehicles in N.America will be the second and third gen Celicas.
If you don't mid other ratios (trading lower top end speed for better acceleration and higher fuel consumption or vice-versa) then RWD Corollas with 2T engines are also an option.
The same web page has donor vehicles listed in the bottom half.
Having said all that, donor vehicles are thin on the ground in wrecking yards.
Try asking for a spare from the guys at
http://autos.groups.yahoo.com/group/classic-celica/
If you're adventurous, you can also consider swapping in a Supra IRS.
Involves cutting off the panhard rod bracket and drilling holes in the chassis rails to mount the IRS K frame.
Not for the feint hearted but doable if you align things carefully.
- Stepho
stepho is offline   Reply With Quote
