rpm down and up - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-26-2009, 02:19 PM   #1 (permalink)
View aye87's Photo Gallery
rpm down and up
hi, after the celica has been warmed up, the rpm keep moving down and up, i just replaced spark plug, wires and checked it with timing light, its 10 btdc, what are the other problem most likely causing this rpm down and up, fuel injector is good, they making clicking noise and i poured gas cleaner
would it be?
timing belt
vacuum leak (rough idel only?)
timing belt havent change since it manufactured, it has 135000 miles
aye87 is offline   Reply With Quote
Old 11-30-2009, 11:51 AM   #2 (permalink)
View whatsyurprob's Photo Gallery
would it be?
timing belt
Timing belt is contributing to your prob. Change it. Vacuum leaks are also known for making the engine "loop". Inspect them all.
whatsyurprob is offline   Reply With Quote
Old 12-12-2009, 02:23 AM   #3 (permalink)
Rick89GTS's Avatar
View Rick89GTS's Photo Gallery
Check all your hoses, sounds like a vacuum leak. What year is your Celica?
Rick89GTS is offline   Reply With Quote
Old 12-12-2009, 08:18 AM   #4 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
how much are the rpms fluctuating?
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 12-12-2009, 03:02 PM   #5 (permalink)
1991 GT
-/+ 300 rpm flucating
Old 12-12-2009, 03:39 PM   #6 (permalink)
View seann's Photo Gallery
have same issue
Fix your problem yet?
seann is offline   Reply With Quote
Old 12-12-2009, 04:37 PM   #7 (permalink)
no i visual checked the vacuum hose, but need further diagnostic
Old 12-12-2009, 08:44 PM   #8 (permalink)
Rick89GTS's Avatar
Check the AFM connections, TPS, ISC valve.
Old 12-14-2009, 02:29 PM   #9 (permalink)
its a vacuum leak
when i hold on the brake pedal rpm go down and maintain not flaunting but once release the rpm shoot back up more than it supposed to then rpm keep flaunting -/+ 300
i cant find the vacuum leak, all hose are connected and no rip i can see
Old 12-15-2009, 06:58 PM   #10 (permalink)
i think is the brake booster
rpm changes as the brake pedal is held
Old 12-15-2009, 08:58 PM   #11 (permalink)
Rick89GTS's Avatar
^Wow, the brake booster?!
That's a new one for me. I'm interested in how this turns out. Please post up your findings!
Old 12-16-2009, 06:54 AM   #12 (permalink)
Banned
View pritty123's Photo Gallery
Need complete info and your problem as needed a detailed explanation.
pritty123 is offline   Reply With Quote
Old 12-16-2009, 11:38 AM   #13 (permalink)
im gonna do the vacuum test on the brake booster but i think that where the problem, brake pedal is hard to depress and rpms changes as pedal being hold
if its not the booster, im goona use the propane method on the vacuum hose, then test each vacuum operate switches such as egr
