a 3sge/gte will be hard and cost some $$$$ because you would need all new engine mounts, the ecu, complely redone wireing harness, most likly diff. or custome axles.
a 2zz is a little more easy but also need new mounts, and ecu
(new mounts means cutting and welding in proper location)
you can also make a mean 1zz n/a there is a kit to make 200bhp and still get like 28mpg look under the 8th gen corolla forum
Its not about what the car can do, its all about what the driver can do.
