94 gt 5sfe Help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-15-2009, 10:35 AM   #1 (permalink)
View snoman65's Photo Gallery
Gen6 94 gt 5sfe Help!
My celica just sputtered and died while driving, I replaced the timing belt,plugs,wires, cap, and rotor about 300 miles ago and it was running great. Now I have checked for spark, timing, and it has fuel pressure and a smell of gas when I crank it over but it will not even fire. Any help would be great. Thanks!
snoman65 is offline   Reply With Quote
Old 12-15-2009, 12:05 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997275
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Test Coil/igniter
The Jedi Speeder at CarDomain
Old 12-15-2009, 12:55 PM   #3 (permalink)
tested the coil and signal generator with a meter and all is in spec. also used a timing light as engine was being cranked and timing was as should be. I was thinking that maybe I had spark but not at right time but that seemed to blow that theory. I must be missing something. Does the ignitor control the injecter pulses? Thanks
Old 12-22-2009, 08:15 PM   #4 (permalink)
Still no luck. anybody got any ideas?
Old 12-22-2009, 08:19 PM   #5 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
hmm. Check for vacuum/pressure leaks next.
Old 01-01-2010, 11:26 AM   #6 (permalink)
View gidbud's Photo Gallery
This happend on my '94 GT too. The ECM was bad. I sent it off for repair, which was successful. For that reason, the plugs were fouled. I cleaned the plugs and it runs fine.
Hope this helps.
gidbud is offline   Reply With Quote
Old 01-01-2010, 06:36 PM   #7 (permalink)
View gorckat's Photo Gallery
Does the new rotor fit the shaft tight? I've had a dodgy one before that was loose and caused intermittent starting and running issues.
gorckat is offline   Reply With Quote
Old 01-06-2010, 04:41 PM   #8 (permalink)
Thanks for the input, I've been busy and the celica got put aside for a bit. I'm leaning towards the ecm being the problem but want to test somemore this weekend before I spend the $. The rotor fits the same as the old one did, I pulled it out of the trash to check it. I'll post more as I figure it out. Thanks again. Don.
Old 01-06-2010, 04:57 PM   #9 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
The wires on the connector to my distributor were so brittle they cracked and a couple of them broke completely. Have you looked at those. Just a suggestion to help you narrow this downand eliminate that as a cause.
Old 02-28-2010, 01:01 AM   #10 (permalink)
Well i'm back to working on the celica, still no luck. This is where i'm at. Timing checks out, I've checked marks from crankshaft to cam gear to distributor and all line up correctly. I have changed the distributor although the old one tested good it needed replaced due to the shaft getting loose and starting to show signs of slight oil leakage. With the sparkplugs removed and in the wires I have good spark. With every thing put together I can hook up my timing light and while it is being cranked over I am seeing the light flash and timing showing 8 degrees btc. My compression tests 150 to 165 which is in spec. On to the fuel system, fuel pressure is good and I drained the tank and refilled to eliminate fuel quality since it quit shortly after a fill-up. Injetors are getting apulse which I checked with node lights and I am flooding cylinders after cranking so I think my fuel system is ok. The only code in the comp. was a coolant temp sensor code and I have checked the sensor and wiring and all look good. I have also checked the map, air temp, and tps and all check ok. Toyota thought it was my ecm so I replaced that and still nothing.
So I'm open for suggestions, any new ideas? Thanks Don
Old 02-28-2010, 05:19 PM   #11 (permalink)
6th gen master
View hatchy_gt-s's Photo Gallery
Check your crank position sensor and your knock sensor. If its not that you are boned cause thats the only thing left that would cause a crank no start.
Its not about what the car can do, its all about what the driver can do.
hatchy_gt-s is online now   Reply With Quote
Old 02-28-2010, 09:39 PM   #12 (permalink)
Thanks, I'll check the knock sensor tomorrow, didn't even give it a thought. The 94 doesn't have a crank sensor. Don
Old 02-28-2010, 11:10 PM   #13 (permalink)
6th gen master
^^^ Um ya it does, its bolted on the bottom side of the cranks timing gear. A crank sensor is what tells your car its at TDC(top dead center)and can add spark and fuel to ignite, any car that is fuel injected will have 1.
Old 02-28-2010, 11:24 PM   #14 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
^ Not neccessarily. My fuel injected MR2 doesn't have one .
