Need Help!!!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-31-2009, 09:08 PM   #1 (permalink)
View john125's Photo Gallery
Need Help!!!!!!
I am in the process of pulling my tranny on a 94 Celica. I was needing advice from someone who has personally already done it. I have looked online via autozone and it say's that the engine suspension members have to be unbolted. So I am thinking it is referring to something like a frame that bolts up the the body that also supports the wheel. Anyway I was wanting to know if it is possible to replace the transmission with out removing that undercarriage support or members? Thanks for any help. Specifically from someone who has replaced a trans on this year or helped with the process.
Here is what I am talking about.
It is figure 4 but the trans is the a246E
http://http://www.autozone.com/autozone/repairinfo/repairguide/repairGuideContent.jsp?chapterTitle=Automatic+Tran saxle&partName=Drive+Train&pageId=0900c152800750a3 &partId=0900c1528007507f
john125 is offline   Reply With Quote
Old 12-31-2009, 09:15 PM   #2 (permalink)
View yotatoter's Photo Gallery
i am not sure if thats the same as the camry,if it is you can pull the engine /tranny combo up from the top
yotatoter is offline   Reply With Quote
Old 01-08-2010, 01:28 PM   #3 (permalink)
celicamaniac
View celicamaniac's Photo Gallery
pull both and replace the seals and gaskets and you will be a lot happier and you are pulling it up instead of going downward with the trans and not getting the car really high in the air to do this either...it is hard to support the engine without a overhead something or other anyway so pull both...and rent a pressure washer and clean it and the engine compartment at the same time... it will look like new ....well really clean ...
celicamaniac is offline   Reply With Quote
