Help with Celica Not Starting - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-09-2010, 04:58 PM   #1 (permalink)
View lowrider961's Photo Gallery
I have a 1987 Toyota Celuca GT Auto.It seems the colder it gets the harder it is to start.I bought a new battery last week.But still does it when I turn over the key you here the starter engague but doesnt turn over, lights and all etc comes on.Once you get it started it will turn over all the time no problem just if it gets colder and sits long just very hard to start anyone got any ideals.
thanks
lowrider961
lowrider961 is offline   Reply With Quote
Old 01-09-2010, 09:52 PM   #2 (permalink)
View toyomoho's Photo Gallery
Check battery cables and terminals (including ground point) for contact and corrosion, include the ground cable between the chassis and engine.
The starter solenoid terminals can wear with usage and result in poor electrical contact.
Might be a starter motor going bad.
The most likely issues are corroded or bad cable terminal connections (due to corrosion) or the solenoid contacts.
Old 01-10-2010, 04:30 PM   #3 (permalink)
Thanks I have looked at the cable and they are ok
Old 01-10-2010, 09:12 PM   #4 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
so, when its cold the starter is turning the engine but it just takes longer for the engine to actually start running right? or is it that the starter itself takes longer to start turning the engine?
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 01-11-2010, 05:06 PM   #5 (permalink)
starter noy yurning when cold
Old 01-12-2010, 10:10 PM   #6 (permalink)
If the cable connections are fine, that'd point me towards the starter motor.
