Originally Posted by edwardr
My reliable mechanic (not a dealer) estimated $550-600 to replace the belt, tensioner, water pump and cam/crank shaft oil seals on my '94 2.2L 5SFE. Dealer would probably be higher. You can get belt/pump kits on eBay for less than $100. I went for a $220 kit that's a little higher quality and also included accessory drive belts, valve cover gasket and spark plug tube seals. Planning on doing it this weekend... allowing at least a full day with 2 of us working on it. It's our first time so won't be surprised if it takes longer. With the money we save, I figure we will probably making about minimum wage when we're done.
More than the money, I like what I learn about a car when I break it down and put it back together for a project like this. The payoff will likely come when I can diagnose and fix a future problem.
Thanks for your responce, i'm most likely going to do it myself for the expierience and savings.
Any idea if it's true on the early-mid 90's celicas you should replace the tensioner with it.
please let me know how it goes, the difficulty, tips you find out, etc... would reallly appreciate it.
