need help on 2004 celica gts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-18-2010, 02:53 PM   #1 (permalink)
View Unknownazn03's Photo Gallery
I have a 2004 celica gts and when I accelerate the tranny slips. Can anyone help me find out whats wrong and how to fix it?
Unknownazn03 is offline   Reply With Quote
Old 01-18-2010, 05:28 PM   #2 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
well is it a manual or automatic?
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 01-18-2010, 05:36 PM   #3 (permalink)
Its a manual 6-speed
Old 01-18-2010, 11:18 PM   #4 (permalink)
what do you mean by slip?
like go to accerate and the rpms shoot up with out real gain in speed?
slipping out of gear?
grinding?
Old 01-19-2010, 10:34 AM   #5 (permalink)
yea the rpm shoots up without any real gain of speed. Sometimes it does it but other times it doesn't. Now it isn't gaining most of the time but after you accelerate for a little bit what happens it finally catches and accelerates.
Old 01-19-2010, 10:34 AM   #6 (permalink)
yea the rpm shoots up without any real gain of speed. Sometimes it does it but other times it doesn't. Now it isn't gaining most of the time but after you accelerate for a little bit what happens is it finally catches and accelerates.
Old 01-19-2010, 12:55 PM   #7 (permalink)
the slipping is probably less when you're in a lower gear, trying to accerate from a higher gear it just slips right?
Your clutch is slipping.
Wow, 2nd time in a week for a 7th gen GTS that a thread was started for this....
Old 01-19-2010, 12:56 PM   #8 (permalink)
6th gen master
View hatchy_gt-s's Photo Gallery
That means your clutch is slipping, alot of hard take offs, or letting off the clutch to slow will cause it to wear. The more you let it slide the more it will wear until you have no acc.
Its not about what the car can do, its all about what the driver can do.
hatchy_gt-s is online now   Reply With Quote
Old 01-19-2010, 01:20 PM   #9 (permalink)
Yea I know that my clutch is going out. I need to know how to fix it or what I should do to fix it. Right now I'm in the process of taking the tranny out and looking at the clutch but I have a problem taking the drive shaft out. Does anyone have any idea on how to do that? I can't seem to get it out but I have taken off the c clamp already. and what do you think it can be the fly wheel or the whole clutch?
Old 01-19-2010, 01:49 PM   #10 (permalink)
I haven't worked on a 7th gen, so honestly I can't give advice on removing the CV axles from the transmission. if toyodiy was still up I'd take a look but yeah...
What is it that you are having problems with?
As for the problem, it would be the clutch disk surface being worn, or the pressure plate not supplying the force it should. But, all this should be replaced while in there since it all comes in a clutch kit, and possibly replace the flywheel or have it turned if the surface is uneven. Should probably replace the rear main seal as well while in there.
Old 02-08-2010, 09:44 AM   #11 (permalink)
jons02gts's Avatar
View jons02gts's Photo Gallery
chances are its is solely the clutch, esp if its stock. had the same thing happen to mine, but the work was done by my wifes brother in law. I would suggest doing what I did, and get a stg 2 kit to replace it with. it will keep it streetable, and improve the overall feel of the car.
jons02gts is offline   Reply With Quote
