battery problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-20-2010, 09:59 AM   #1 (permalink)
View invincibleruler's Photo Gallery
battery problem
Sometimes my car just doesn't start because the battery is completely dead. The battery gets dead even in like 2 hours sometimes.
I try to start the car using the jumper cables but that never works. But it works quickly when I use a Jump Starter.
Is there something wrong with my car's battery or the car itself?
Do I need to buy a new battery? If yes which one should I get?
Thanks for the help
2002 Celica GTS
invincibleruler is offline   Reply With Quote
Old 01-20-2010, 07:33 PM   #2 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
if its draining while not running (meaning no problems while the engine's actually running) sounds like its now a heavy corrosive poisonous paper weight.
Although I'm not sure why using jumper cables hasn't worked but a jump box has. they're practically doign the same thing. maybe improper use of jumper cables?
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 01-21-2010, 04:27 AM   #3 (permalink)
RA28 + MX73
Gameroom cash: $107620
View stepho's Photo Gallery
Sounds like a dead battery.
Can you check the water level in the battery or is it a new, no maintenance type?
Try borrowing a friend's battery for a day and see if it performs better.
A jump box has much more amps than using jumper cables with a second battery.
If your own battery is in bad condition then it will suck up a lot of the power coming from the second battery - leaving only a little to start the car with.
- Stepho
stepho is offline   Reply With Quote
Old 01-21-2010, 09:46 AM   #4 (permalink)
I got it checked at Advance Auto Parts yesterday and they guy said that I would need a new battery.
Which one will be good - http://shop.advanceautoparts.com/web..._1129235481___
or
http://shop.advanceautoparts.com/web..._1048338420___
Thanks for your replies.
Old 01-23-2010, 03:33 PM   #5 (permalink)
Gameroom cash: $139205
View 93celicaconv's Photo Gallery
Battery selection is really a matter of your choice, how much you are willing to pay and how long the warranties are on them. Consumer Reports tests automotive batteries a lot, so if you know your size, you could check consumers report and make a selection that is right for you.
After you have your new battery in, have Advance Auto Parts check your entire electrical system with their tester. It's free, and it's a good idea to make sure you don't have any problems with your alternator or a current drain on your system when you car is turned off.
93celicaconv is offline   Reply With Quote
Old 01-23-2010, 06:04 PM   #6 (permalink)
the last consumer reports I saw ranked kirkland and autocraft batteries both at the top.
But, knowing from experience (being the commercial parts pro at an Advance) there are still a fair amount of battery defects that I see, even in the Silvers and Golds. So I suggest the gold just for the warranty, company policy is to just replace the batterys and even the prorating after the free replacement period is still good compared to buying a new battery.
The economys are 1 year free replacement. golds are 3 years with a total of an 84 month warranty.
Regardless of where you go though, Autozone, pepboys, who ever, just try to get one with a decent warranty, with such a high failure rate, its worth it.
Old 01-24-2010, 08:50 AM   #7 (permalink)
Bitter's Avatar
Gameroom cash: $559600
View Bitter's Photo Gallery
http://www.google.com/#hl=en&source=...0a4630ce98f7da
