I guess take a look at everything while you're taking things apart, try to replace rubber parts (insulators, strut mounts etc) if worn/cracked.
If you have access to a shop you should have everything you need. I guess try to make sure you also have a torch available, the bolts on the bottom of the strut housing that conneted to the knuckle were held in with red loctite, had to heat them to break them loose.
If you have any questions at all, I'll be glad to help.
'11 Kawasaki Ninja 250R, '12 Mazda2
