IF it has a chipped ECU, it's worthless.
As far as a performance AFM, never heard of one. I'm not saying it doesn't exist, but the AFM's only function is to measure air flow and tell the ECU how much fuel to send. The only upgrade you could do to it is to make it send ALITTLE more fuel-which in itself is pointless unless you have a biiger, aftermarket turbo. The only upgrade for measuring the air flow is to remove the AFM and use some type engine management electronics such as Greddy Emanage or Hydra Nemesis, etc.
The 3sgte runs rich as it is, as intended by Toyota.
Sounds like this car may end up being more trouble that it's worth-unless you have the time and money to make it right.
In the end, it really depends on what it worth to you and how far and how much are you willing to put into it.
