Basic How to: Engine-Crank no start(Fuel Injected vehicles)
I will start of with the basic steps that anyone can do in their drive-way.
NOTE: THIS IS FOR ANY VEHICLE WITH DISTRIBUTOR.
NOTE: WHEN CRANKING NEVER EXCEDE 10 SEC. OF CRANKING AND ALWAYS KEEP YOU BATTERY FROM GOING LOW.
I will be covering Fuel and Ignition.
FUEL
Step 1:Check fuel pressure, there will be a relief valve located on the fuel rail(looks like a tire pressure valve), press the valve till no more fuel squirts out.
Step 2:Crank the engine over for about 5 seconds, and recheck the valve.
-If fuel then move to Step 1 of Ignition. If no fuel then move to Step 3 of Fuel.
(Step 3 best done with 2 people, BUT is able for 1 person)
Step 3:Checking furl pump, Turn the key to the off position, wait 5-10 seconds then turn the key too the ON position, If you hear a whine then your fuel pump is working and you can move to Step 1 of Ignition. If you do not hear a whine ask a friend and or relative to slide under the car to hear for the whine as you crank the engine.
-If no sound then check for voltage at fuel pump(refer to manual)
Step 4: Checking fuel injectors, There are 2 ways to do this. Part A is not covered fully. Part A&B requires 2 people
A: Use voltage meter and or injector nodes(can be found at local automotive store)
B: Take a flat head screw drive, place the tip on the injector, then place your ear on the handle and listen for a very fast ticking noise.
-If you hear this noise on all injectors then your injectors are in working order. If no sound move to Step 4 of Ignitions.
IGNITION
Step 1: Check for spark, easiest way to do this is remove the spark plugs, insert them back into the wires and place the threads of the plugs onto a grounding point.(DO THIS PROCESS 1 PLUG AT A TIME)
Good Grounding points: Valve cover, Strut bolts, Exhaust manifold.
-If you have spark move on to Step 1 of Intake(Not covered in this How to). If no spark move on to Step 2 of Ignition.
Step 2: Check wires, There are 2 ways of doing this.
A: Use a volt meter.
B: Take a screw driver, place the tip in the wire and hold the screw driver close to a grounding point.(MAKE SURE YOU ARE NOT TOUCHING A GROUND POINT AND NOT TOUCHING THE METAL OF THE SCREW DRIVER)
-If you have spark move to Step 1 of Intake(Not covered in this How to). If no spark move to Step 3 of Ignition.
(Step 3 is for separate ignition coil)
Step 3: Check Ignition, There are 2 ways of doing this.
B: Remove the ignition wire from the distributor, place wire connection close to the hole it was removed from and crank the engine.
-If you have spark then move to Step 1 of Intake(Not covered in this How to). If no spark then move to Step 4 of Ignition.
Step 4: Check fuses.(This is self explanatory)
If all is in working order please contact your nearest automotive shop and or parts place for further assistance.
Its not about what the car can do, its all about what the driver can do.
