I believe the AllTrac comes with the 3sgte?
More air + fuel =more power.
I guess 400hp@ the crank would equate to around 340-350 @ the wheels.(just guessing)
The 3sgte, with it's iron block and it's stock internals are good to 400rwhp.
Of course, forged internals are always better.
Wiseco, JEPistons,Eagle all make great products-$700.00-$800.00
You'll need a bigger turbo. A GT28, GT30 or TD06 to hit those numbers..$$1,100.00
Upgraded IC , piping, couiplers andT-clamps-$400.00-$800.00
If you're gonna rev past Redline, or use higher lift cams,-$600.00-$700.00
you will need to upgrade the valvetrain.
Adjustable Cam gears-$200.00
For my head rebuild/upgrade, I went with the shimless lifters from the MR2Spyder 1ZZ engine.-$192.00
Brian Crower springs,titanium retainers,$250.00
Ferrea SS Valves-$225.00
550cc (or bigger) injectors-$400.00( certain yr. Supra injectors are plug and play using stock fuel rail)
Higher capacity fuel pump-Walbro 255lph is pretty popular-$100.00
Downpipe-$275.00
Upgrade the exhaust-$600.00-$700.00
Boost controller of some type
Anything beyond 280rwhp is gonna require some type of engine management. Like MegaSquirt, Hydra Nemesis,etc. A tuned ROM might get you there.
Upgraded clutch. The stock 3sgte clutch is only good to 280hp=$400.00-$500.00
Reason: Correction
