hi, i'm new to the board but i have a couple of questions for you guys.
i have a 91 celica alltrac turbo and i am having an issue with it. i just had the oil feed line replaced because it was bad and leaking oil everywhere. anyway, now the turbo has another problem. it seems like it is leaking all around the actual blower and has gotten up onto the heat shield as well. i'm not exactly sure what it is though. could it be the oil feed line again? or could the spindle have gone out and it's leaking oil from the turbo itself? when i try to accelerate, the boost guage reads hardly any boost, but it does go up a little... any ideas what it could be? if it's the feed line, i'll take it back to the mechanic who replaced it.
also, if it is the turbo itself, i was thinking about replacing it. what turbos should i look into. i'd like something with a performance gain, like a t3/t4 hybrid or something like this
one
my only problem is that i don't want to spend too much money on this so i don't want to replace the turbo manifold and downpipe. would something like this bolt up without any other modifications?? if not, do you guys have any suggestions?
any advice is welcome
thanks in advance.
