1881 toyota celica headlights and blinkers are not working - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-19-2010, 10:40 AM   #1 (permalink)
View celicanator's Photo Gallery
2nd Generation 1881 toyota celica headlights and blinkers are not working
i have a 1981 toyota celica and all of a sudden last night after i went to the grocery store my headlights and blinkers where not functioning. my hazards work fine. but when i turn on a blinker nothing will even go on on the dashboard. and all the fuses are fine i cheked them. anyone knw what else could it be?
celicanator is offline   Reply With Quote
Old 03-20-2010, 05:54 PM   #2 (permalink)
RA28 + MX73
Gameroom cash: $107620
View stepho's Photo Gallery
How did you check the fuses?
Visual inspection isn't enough.
I had a glass fuse stop working last week.
Looked fine but didn't pass any current through.
I normally bridge the contacts of the fuse holder with my key.
If things start working again then the fuse was bad.
Another culprit is bad grounds.
Look for wires that bolt to the body.
Often rust gets underneath the lug and breaks the contact.
For me it was the ground wire between the two tail lights but yours could be anywhere under the dash.
But since your hazards work, I'd guess that your problem is the switch itself.
Get a circuit diagram (the Haynes manual is worth getting just for this) and bridge the switch connections with a piece of wire.
If it works then the switch needs replacing.
- Stepho
stepho is offline   Reply With Quote
Old 03-21-2010, 07:31 AM   #3 (permalink)
Gameroom cash: $139205
View 93celicaconv's Photo Gallery
You may want to check the wiring harness connection point at your steering column. Do you have anything else on your steering column that involves switches? If so, do those items still work? Perhaps you accidentally got your foot or leg on the wiring connector that goes into your steering column and pulled it apart.
93celicaconv is offline   Reply With Quote
Old 03-21-2010, 12:12 PM   #4 (permalink)
6th gen master
View hatchy_gt-s's Photo Gallery
OT but
Hm I didnt know they made the celica in 1881jk man.
(look at the post header)
Its not about what the car can do, its all about what the driver can do.
hatchy_gt-s is online now   Reply With Quote
