Idle really rough -Video attached - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-24-2010, 03:37 AM   #1 (permalink)
View rona3s's Photo Gallery
I do have issues with my 3sgte , idle really rough . The video showed once I start the car engine. and idle
visit:youtube.com/watch?v=bqi3l6bMn34
LT8s
3sgte
540cc
gt35r
internal all stock
does this related to any vacuum leak ?/ mechanical issues / setting in microtech or related to miss firing ? spark plug / cable plug ?
I do not have issues on high rpm / 1500 rpm and above.
Thanks for your advice.
rona3s is offline   Reply With Quote
Old 03-24-2010, 12:24 PM   #2 (permalink)
jlspec's Avatar
View jlspec's Photo Gallery
Check your plugs, wires, and distributor. Also make sure you have the correct engine management settings for your 540cc intectors. Check around your throttle body for leaks which includes vacum lines, and gaskets. Then finally the other only reason is your injectors or fuel pump.
1990 Celica Turbo All-Trac
jlspec is offline   Reply With Quote
