no spark need help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-25-2010, 07:46 PM   #1 (permalink)
View oldblue87's Photo Gallery
no spark need help
i got a 91 celica 5sfte it has not spark. i have replaced coil, distributer, replaced igniter with one from a junk yard. after i put coil in i have it wired up wrong got wired up right now it started and ran. but died again and has no power to coil or distributer. i am thinking maybe a engine relay but have no idea. Any help would be great.
oldblue87 is offline   Reply With Quote
Old 03-26-2010, 06:15 AM   #2 (permalink)
Gameroom cash: $139205
View 93celicaconv's Photo Gallery
What events led up to the 1st time you discovered that you didn't have spark (did it come up right after an engine replacement, or some major work)? What kind of testing capability do yo have? And how did you test for spark in the first place?
93celicaconv is offline   Reply With Quote
Old 04-02-2010, 04:55 PM   #3 (permalink)
no major work has been done. msd coil just went bad but i wired it up backwards. got that worked out then it started ran for about and hour then drove it down the road and it died. tested air gap in distributor and it was .020 and i think that the max is .016 so replaced it. still no start. used multimeter to test for voltage on coil and distributor did not test igniter but if coil is not getting voltage then it probly is not. i am thinking ecu but just want some input form someone else
