Dome light and tails light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-05-2010, 10:38 PM   #1 (permalink)
View celica93's Photo Gallery
Hi all, i have 1993 Toyota Celica GT and yesterday while driving, speedometer light and tail lights went off suddenly, i have changed the fuse ,yellow one,15V 20Amp, changed the fuse under the stering wheel and also under the hood, but the lights are still off, any suggestions, help would be really appreciated.
Thanks in advance.
celica93 is offline   Reply With Quote
Old 04-06-2010, 06:17 AM   #2 (permalink)
Gameroom cash: $139205
View 93celicaconv's Photo Gallery
Did you change all these fuses because all were blown?
Do your front lights work?
93celicaconv is offline   Reply With Quote
Old 04-06-2010, 09:32 AM   #3 (permalink)
The front lights are working just fine..
Old 04-06-2010, 09:53 AM   #4 (permalink)
No reply regarding the fuses you changed, if they were blown?
Above your driver's side kick panel, you have a fuse block. Fuse 9 is a 15A TAIL fuse. This fuse protects your tail lights, parking lights, side marker lights, license plate lights, instrument panel lights, and glovebox light. Check if any of these light work when your have your lightswitch on. If any lights work, then this fuse and the wiring support it are fine. There will be a problem downstream of this fuse that needs to be diagnosed. But check this first and let us know.
Old 04-06-2010, 11:05 AM   #5 (permalink)
Thank you for the quick reply, as for the other fuses, i did not changed any other fuse just the yellow one,and i will definitely check fuse 9 in the evening.
Old 04-06-2010, 11:19 AM   #6 (permalink)
I would first check if any of the lights in thread #4 work with the light switch on before checking fuse 9. First step first! No need to worry about fuse 9 if any of the lights listed in thread 4 work.
Old 04-06-2010, 10:05 PM   #7 (permalink)
Thanks a ton buddy, i checked the glove box light and other lights and they were off, pulled out the fuse for tail light, fuse number 9, it was smoked, all black, changed it and all the lights are back on. Thanks a lot for the information, saved me a lot of time and hassle.
Old 04-07-2010, 07:32 AM   #8 (permalink)
Glad to be of help. That is what these forums are all about!
