1988 all trac questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-09-2010, 07:38 PM   #1 (permalink)
View colbyjenner's Photo Gallery
ok so im looking at getting a 1988 alltrac that has been sitting for a long time and the guy says its slugish cause the injectors need blown out. It also has an exhaust leak and is said to be very loud when the turbo kicks in. Is this safe to drive? I live 5 hours from the car and would have to drive it back and dont want to damage the engine or turbo. Any suggestions that i should do to the car before driving it home. I was thinking of an oil change and trying to fix the exhaust but idk if ill be able to. The car has been sitting for some time until the current owner started it and said hes driven it 15 miles. About how much is an ok 1988 all trac worth?
Thanks for all the help,
Colby
colbyjenner is offline   Reply With Quote
Old 04-09-2010, 09:51 PM   #2 (permalink)
View blkavalon's Photo Gallery
i am not good with turbo charged vehicles to give advise on. but i have to let you know that you are very lucky to find that car. those are extremely rare cars. i had a camry all-trac it was the best car i ever had. this is a celica and it is turbo charged for me it worth alot.
98 Avalon XLS, 91 Camry, 78 Corvette, 92 Saab 900,
05 Yamaha R6 Raven, 81 Suzuki GS 650L,
blkavalon is offline   Reply With Quote
The Following User Says Thank You to blkavalon For This Useful Post:
colbyjenner (04-09-2010)
Old 04-09-2010, 10:21 PM   #3 (permalink)
i am going to look at the car sunday so need help asap.
Thanks,
Colby
Old 04-09-2010, 10:56 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997575
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
1st of all, how long has it been sitting? Did they start it once in awhile? These things do make a difference.
Assuming that you've test driven the car for several miles and it runs decently, I would definately change the oil.The stock turbo in the AllTrac uses a floating bearing and dirty oil is bad for it.
Depending on how long it's been sitting, I would be concerned about the fuel too.
Check all the fluids. Some fresh plugs would be good/safer too. I would hate to see you stuck somewhere hours from home.
How badly the exhaust leak affects the turbo depends on where the leak is-at the manilfold before the turbo, you will loose boost as some exhaust energy never makes it to the turbine.
If it's after the turbo you will have boost creep and spikes .
Just take it easy and don't push it.
5 hours is a long way to drive a car thats been sitting.
The Jedi Speeder at CarDomain
Old 04-09-2010, 11:04 PM   #5 (permalink)
hey thanks for the help. Its been sitting for a while like a couple yrs prior to the current owner purchasing it and driving it only 15 miles. I am going to get an oil change before heading home and going to put alluminum foil and clamps over the leak. Anything else i should check/replace? Anything i should look for before purchasing it?
Thanks,
Colby
Old 04-09-2010, 11:12 PM   #6 (permalink)
Bitter's Avatar
Gameroom cash: $559600
View Bitter's Photo Gallery
the tires are probably junk as are the brakes after sitting like that. seriously consider having it transported to you by a car mover. it should only be a few hundred dollars or less and you won't wreck your new purchase.
Old 04-10-2010, 12:23 AM   #7 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Honestly, I wouldn't drive it 5 hours without servicing the brakes, cooling system, full ignition system tune up, a fresh battery, draining the old gas and replace with fresh (91octane or higher), oil change, and decent tires.
Piggy back on a tow truck would be the way I would go-as suggested by Bitter.
Best of luck with whatever you decide.
Old 04-10-2010, 10:18 AM   #8 (permalink)
thanks for all the help. I have one more question would the check engine light be on due to the exhaust leak? Also can you get codes pulled from a car this old at napa or autozone?
Thanks,
colby
Old 04-10-2010, 12:16 PM   #9 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Not neccessarily.
Don't know. Do you have a manual for the car yet? If so, you can get a paper clip, cross connect TE1 and E1 in the diagnostic port, turn igniton to on position-WITHOUT STARTING THE ENGINE- and count the CEL flashes.
ex.= 5 flashes, pause, then 2 flashes = code 52
Then look up the corresponding code.
Old 04-10-2010, 12:24 PM   #10 (permalink)
Is there a write up of how to do this? And the code meanings?
Thanks,
Colby J
Old 04-10-2010, 12:31 PM   #11 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I just explained it. It's that simple. You can do a search here.
We have the same engine, but the location of components in the engine bay are probably different.
The diagnostic port is labeled "Diagnose"
Old 04-10-2010, 02:19 PM   #12 (permalink)
09yota's Avatar
View 09yota's Photo Gallery
Funny that this post came about. I have an 09 Rolla S and I just bought a 1988 All-Trac last week. Car is awesome. Motor pulls strong. It actually sat in the previous owners back yard for about 8 months. I went there, replaced all the plugs, changed the oil, and drove it right home. Granted, it was only 15 minutes. I have been driven the car about 100 miles since purchase. I replaced the front CV Shafts, and all the inner and outer tierods, and flushed the differential fluid today. The turbo was rebuilt about 5k miles ago. Honestly, I would drive the car your considering buying before you even buy it. I paid 2,000 for mine if you were wondering on price. I have some pictures on celicatech.com. Here is the craiglist ad from buying it if you wanna check out the condition and compare.
http://richmond.craigslist.org/cto/1665931819.html
Anyways, I know this was long and babbled on about a whole lot of nothing, but if your confident with the car get it. i have been SO happy with mine thus far and I am really excited about future mods to it...
2012 Camry SE V6 fully loaded- DD
2005 Corolla XRS- fun car.
PS- I work for Toyota, if you have any dealership questions, then let me know!
09yota is offline   Reply With Quote
Old 04-10-2010, 06:52 PM   #13 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
There's alot of aftermarket support for the 3sgte engine in it. You can easily hit 280hp with simple upgrades.
Old 04-10-2010, 08:21 PM   #14 (permalink)
thanks for all the responses. I am getting the car tomorrow and am trailering it. Anything i should put special attention to when test driving and over looking the car?
Thanks,
colby
Old 04-10-2010, 08:48 PM   #15 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I'm glad you decided to trailer it.
A test drive will tell you much. Look for oil leaks, rust, check suspension for bent parts. The usual stuff when buying a car.
