How much would a Turbo 5s-FTE setup cost? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-19-2004, 10:09 PM   #1 (permalink)
View Zrain's Photo Gallery
how much would it cost to make a 5s-FTE kit? for a 91 Celica?
list the parts and price as best as u guys can? you think it can be done for less then 2grand?
1991 Toyota Celica Red, Gray Interior, 5spd, 2.2L
My New Toy 3-1-04
Zrain is offline   Reply With Quote
Old 03-19-2004, 10:24 PM   #2 (permalink)
http://www.poweredbytoyota.com/ssfeturbo.html
this system looks promising, but id like to know more before i drop 2500 dolors for it.
My New Toy 3-1-04
Old 03-19-2004, 10:34 PM   #3 (permalink)
Lol i just got talking with my budy.. im going to do a 3s-GTE swap... for 1250 bucks i can get an import motor with like 30-40k on it... and thats ALOT cheeper then a turbo system.. with MUCH more power
My New Toy 3-1-04
Old 03-19-2004, 10:42 PM   #4 (permalink)
Ignore this post.. lol
My New Toy 3-1-04
Old 03-20-2004, 03:05 AM   #5 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
you can delete posts... simply click edit, then at the top check the delete box, then onthe right click delete...
also, an engine alone wont do much... you need motor mounts from an alltrac..., ecu, complete wiring harness, ignitor, map sensor, alternator, a/c condenser, power steering pump, belts, replace all hoses that were cut... trust me i just did an engine swap... you dont want to do this without an alltrac front clip...
look it up!
also you can do a turbo kit for 900 bucks in parts... then piping and exhaust needs to be bent and welded... stuff like that.
where in CT? i could help you do the swap if you need help... or turbo whatever you want to do... or if you dont have the skills, i can do it for you and charge you...
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 03-20-2004, 10:15 AM   #6 (permalink)
im over in newtown. if i was to do the swap id be buying a full front clip. if i was to do the turbo kit, the only hold up it the down pipe, and cat. evry thing else i can get in there no trouble. only set back would be the fact that spending 900 to make a 5s-FTE when i can spend 1600 or so for a full 3s-GTE dosent make make scence when the 5s-FTE would top off in HP at around 200. now biulding up the 5s bottem end would help alot but then im just throwing money at a problum, insted of throwing money at a good idea.
ither way if i do somthing, anything at all.. a fellow TN members help is always welcome
My New Toy 3-1-04
Old 03-25-2004, 03:32 PM   #7 (permalink)
View luisitol's Photo Gallery
dude who told you a 5s tops out at 200hp? There are 5sfte camrys out there with more than 200hp and dont' hav ebuilt bottom ends.
good luck with your engine swap
'93 Probe GT - Daily Driver
'93 LE - Show Car - Coming SOON
luisitol is offline   Reply With Quote
Old 03-25-2004, 05:07 PM   #8 (permalink)
View Deep's Photo Gallery
For how long.
Deep is offline   Reply With Quote
Old 03-25-2004, 06:09 PM   #9 (permalink)
I'm a Mac
zoni's Avatar
for 200 hp i would say you need 7-9 psi of boost. that is safe in an everyday situation. the only thing i might worry about is the head gasket.
Dave Zoni
Old 03-25-2004, 06:31 PM   #10 (permalink)
Rod bolts and bearings too.
Old 03-25-2004, 09:31 PM   #11 (permalink)
View fullraceGTS's Photo Gallery
This topic is funny to me, a 5SFTE highest numbers I have seen is well over 500hp. Mike Colin runs it on a MR2. Want the link?
You can build a basic kit for less then $1000!!
Basic Kit
Supra Green top injectors
3SGTE exhaust manifold
CT 26 turbo
2 bar map sensor
3SGTE oil pan or modded 5S oil pan with return line hole
coolent hoses
turbo to manifold pipe
welded up custom exhaust to mate to the 3S downpipe
That is it.
John L.
fullraceGTS is offline   Reply With Quote
Old 03-25-2004, 11:57 PM   #12 (permalink)
I'm a Mac
zoni's Avatar
^ true...
deep, i wouldnt worry about the bottom end till 300hp honestly...
maybe you are more careful than i, but i really wouldnt worry about it.
Dave Zoni
Old 03-26-2004, 12:10 AM   #13 (permalink)
my bottem end has 165k on it tho... but ive swaped back over to the 5s-FTE camp a 3s-GTE would be nice.. but i thick i will wait before i drop somthing like that into a perfictly runing car..
all i need to realy do now is find the parts.
My New Toy 3-1-04
Old 06-22-2004, 12:33 AM   #14 (permalink)
Banned
View fiveSFE's Photo Gallery
u donnot need motor mounts from an all trac for the 3sgte swap, and u can just build ur own turbo system for the 5sfe, u would need exhuast manifold, ct20b turbo, 3sgte oil pan, injectors, and probly a map sensor from an older turbo supra, or an all trac., and custom oil lines for the turbo, u can probly acquire all these parts for less than 1500, ive seen exhuast manifolds with turbos for 150, and oil pans for 120 brand new
fiveSFE is offline   Reply With Quote
Old 06-22-2004, 01:09 AM   #15 (permalink)
I'm a Mac
zoni's Avatar
supras dont use map sensor.
Dave Zoni
