17 inches voxx rims for 91 celica? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-20-2010, 03:17 PM   #1 (permalink)
krazytom91's Avatar
View krazytom91's Photo Gallery
im thinking of getting 17 inches for my celica. but idk if there would be a problem if i put it on? can sumbody help?
krazytom91 is offline   Reply With Quote
Old 04-21-2010, 09:50 AM   #2 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
Yes, 17s fit fine. I'm running 17x7s right now. BUT it all depends on what offset they have, how wide they are, and what size tire you are going to run. Also, what kind of celica? the GTS is a widebody and has more room than a narrowbody.
I am running: 17x7, +42 offset, with 215/45/17 tires on a narrowbody coupe. The tire clears the strut housing by about 3/4 an inch and sits about 3/4 from the edge of the fender well. I get a tiny bit of rub in extreme circumstances(several passengers, turning, and hitting a larger bump sort of circumstances) but that could be fixed by rolling the inner fender lip back a little.
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 04-21-2010, 02:29 PM   #3 (permalink)
krazytom91's Avatar
well my celica A GT
n i ask a couple ppl around n they said they would fit. im just scared that if i get tha wrong type of rims n tires my car wont able to drive like normal b4.
but yea i had an idea of going 215. now i jsut need to kno the offsets n etc
Old 04-21-2010, 05:45 PM   #4 (permalink)
yeah, wheel fitment is sometimes a bit tough, the wheels on my old corolla had too high of an offset so rubbed the rear struts and would rub at full lock. I guess try to shoot for around +40 offset on a 7 inch wide wheel.
Also one more thing, its a pet peeve of mine, but please as much as possible, avoid texting language on forums. I can understand it fine since I grew up around the stuff, but many frequent these forums are older so you have to take this into consideration. Forums (automotive esp.) are often used for research and technical information so without the use of at least somewhat proper grammar and spelling information can become cryptic or just simply difficult to read.
I'm not trying to bust your chops, its just something to take into consideration.
Old 04-21-2010, 09:23 PM   #5 (permalink)
krazytom91's Avatar
what you mean by +40 offset im new to this.
yea no problem man. thanks for keeping me on check. that be fine with me man =)
Old 04-22-2010, 07:37 AM   #6 (permalink)
Whenever you buy wheels, offset is something you have to account for. Essentially it determines how the wheel sits compared to the mating surface. Offset is the measurement from the middle of the wheel to the mating surface with the hub (where your wheel contacts the hub, that the lugnuts go through)
FWD cars usually use a higher offset while RWD usually use an offset closer to zero.
The Narrowbody(like what you have) requires approx a +40 offset, so the hub mating surface will be 40 mm away from the center of the wheel. Anytime you buy wheels this information is readily available.
If you cant find the exact offset, if you buy ones with a lower offset, closer to zero, it will bring the wheel further out towards or out of the fender. If you buy ones with a higher offset the wheels will sit more inboard
