Gas not getting to fuel injection under load. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-21-2004, 04:29 PM   #1 (permalink)
View duce406's Photo Gallery
1987 Celica GT 2.0, fuel is not going to injection system upon acceleration car quits, but in park it's OK only when put under load in drive.
Thanking you in advance for any assistant.
duce406 is offline   Reply With Quote
Old 03-21-2004, 05:25 PM   #2 (permalink)
View AZJeepdad's Photo Gallery
Fuel pressure regulator would be my first guess
ASE Undercar Specialist, UTI PHX automotive instructor driving a 1988 ST162, 3SGE, 5 speed. AFM mod and 15 degrees of timing on a otherwise stock vehicle (so far)
AZJeepdad is offline   Reply With Quote
Old 03-21-2004, 06:25 PM   #3 (permalink)
GT-i Crew
lcarocha's Avatar
View lcarocha's Photo Gallery
Fuel pump failing under pressure or clogged fuel tank filter (if the pumps starts to work under load and the filter is clogged there is a chance fuel will not flow so smoothly because of the dirty filter)
Luis C.
92 Celica GT-i (ST182)
2nd Gen 3S-GE
Caracas, Venezuela
http://www.cardomain.com/id/luis_c
lcarocha is offline   Reply With Quote
Old 03-22-2004, 10:43 PM   #4 (permalink)
View OEMonkey's Photo Gallery
check fuel pressure. check injectors.
check sensors used for fuel trim- afm, map, maf, tps, iat, dont really know what your celica has.
OEMonkey is offline   Reply With Quote
Old 06-27-2004, 09:47 PM   #5 (permalink)
I do NOT exist ...
View KAOS's Photo Gallery
well, my sister's Celica is acting up and i'm trying to figure out if i need to remove the injectors and have them cleaned. she has had fuel filter issues in the past, but i'm thinking that some of the crap may have missed the filter and made it up front to clog the injectors.
anybody have any similar issues that may shed some light on what i should do about it?
thanks.
My pride and joy ...
KAOS is offline   Reply With Quote
