Alarm help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-24-2010, 09:21 PM   #1 (permalink)
View bigdog123's Photo Gallery
Alarm help
New to me 1996 Celica convertible. Battery went dead, and now the alarm goes off every time I open the doors. Any ideas? I have never had an alarm on a car. There is no obvious shut off on the key.
2010 Tundra TRD
1996 Celica Convertible
bigdog123 is offline   Reply With Quote
Old 04-25-2010, 09:55 AM   #2 (permalink)
Found a small toggle switch near the clutch. Key in "on" position, flipped switch, alarm off!
Since we don't even lock our houses here I don't have much experience with alarms.
2010 Tundra TRD
Old 04-25-2010, 09:21 PM   #3 (permalink)
RJB92ToyotaCelicaGT
View RJB92ToyotaCelicaGT's Photo Gallery
USA
If is like other Celicas, it uses a remote that has to be detected by the system. The remote will lock/unlock the doors and enable/disable alarm.
To program in a remote:
1. Insert the ignition key and turn it to the RUN position.
2. Toggle the switch you found under the dash above the clutch on/off three times at rate of about once per second
3. Stop with the switch in the off or valet position
Dash turnsignal indicators should flash 3 times to indicate it is ready to receive the signal from the remote. If they do not flash, go back to step 2 and try again.
4. Press button on remote and turn indicators should flash to indicate detected.
5. Turn toggle switch back to the ON position.
6. Remove ignition key
7. Test door locks/alarm.
Didn't look this up for your specific model but thats the way it works for a 92 Celica GT.
You can find remotes for this system online at several places (with programming instruction included) but before ordering, you will need to know if is factory-installed or dealer-installed. The dealer should be able to tell you if is factory or not from the VIN.
Good Luck,
RJB92ToyotaCelicaGT
RJB92ToyotaCelicaGT is offline   Reply With Quote
