rubber silicone - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-28-2010, 10:10 PM   #1 (permalink)
View Hacken's Photo Gallery
rubber silicone
i had to drill a hoe about the size of a penny but little bit smaller behind the rear quarter under the right back tire to do some dent work. so i put a plastic plug in and seal it with those brush on wet silicone rubber maker. my question is are those tough enough to handle the wisconsin snow weather? i hope so... because i don't want snow to get into the hoe and rust out that panel.
Hacken is offline   Reply With Quote
Old 04-29-2010, 12:11 PM   #2 (permalink)
Gameroom cash: $139205
View 93celicaconv's Photo Gallery
I think the silicone sealant is a good idea to hold your plug in place and keep it water tight, but I think the silicone is too soft to hold up long in Wisconsin winter driving (sand/salt being thrown around at highway speeds).
I would suggest you visit a body shop and ask them what kind of material you can apply in the wheel well (assuming this is the area you put the plug into) to coat over the silicone/plug patch area to give the outside surface some better durability. It may be tough to get something hard to stick to soft silicone, but I think the body shop would have a good recommendation for you.
93celicaconv is offline   Reply With Quote
Old 04-29-2010, 01:44 PM   #3 (permalink)
would a body shop actually tell me what i would have to apply over? i know some body shop here in milwaukee they don't want to give any advice unless you are paying them to do a job. i wonder if i can put some black ultra permatex adhesives sealant over it...?...
Old 04-29-2010, 02:55 PM   #4 (permalink)
Gameroom cash: $147537
You can bondo it.
Polyurethane for home. Check out home depot or other building supply store. Get exterior one that adhere to everything and stay soft.
You should cover all bare metal with paint or rust inhibitor first. Even inside the penal.
Old 04-29-2010, 03:13 PM   #5 (permalink)
Originally Posted by Pineapple View Post
You can bondo it.
i wouldn't want to bondo it either. it's only about the size of a dime. i'm thinking about trying the permatex black silicone adhesive sealant. i need some thing that will harden up after it's dried.
Old 04-29-2010, 03:38 PM   #6 (permalink)
Silicone stay soft after it dry. You can JB Weld if you want it hard.
Old 04-29-2010, 05:24 PM   #7 (permalink)
that's the part i hate. it's soft. probably end up putting a little bondo on the hoe if i have no choice and then just spray paint it black.
Old 09-29-2010, 10:05 PM   #8 (permalink)
View robj6767's Photo Gallery
I wouldn't trust the silicone to hold up in the winter
robj6767 is offline   Reply With Quote
Old 09-30-2010, 10:03 AM   #9 (permalink)
RA28 + MX73
Gameroom cash: $107620
View stepho's Photo Gallery
Try a fibreglass repair kit.
The resin bonds to the metal panel and the fibreglass provides strength.
- Stepho
stepho is offline   Reply With Quote
