5SFE sensor on cylinder head - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-05-2010, 09:21 PM   #1 (permalink)
View Hacken's Photo Gallery
Gen5 5SFE sensor on cylinder head
does anyone know what this sensor is for on the 90-93 5SFE? do i need this sensor to run properly?..
thanks!
sorry, stole some one's pic
Hacken is offline   Reply With Quote
Old 05-05-2010, 10:50 PM   #2 (permalink)
Official TN Toaster
iToaster's Avatar
Gameroom cash: $349795
View iToaster's Photo Gallery
That's your oil pressure switch, if you disconnect it your oil light will stay on constantly... but it's not essential to engine operation.
1995 Corolla DX - 7A-FE - 5 Speed - 8K1
2000 Celica GT-S - Supercharged 2ZZ-GE - 6 Speed - 3P0
RIP white Corolla
iToaster is offline   Reply With Quote
Old 05-06-2010, 05:49 AM   #3 (permalink)
how come some of the 5SFE cylinder heads i see on ebay doesn't have that sensor or drill hoe on that spot?..?.. for that sensor is that actually a sensor where it's drill into the head or just like a screw where it just screws in?...
Old 05-06-2010, 04:19 PM   #4 (permalink)
Official TN Toaster
iToaster's Avatar
I did a quick eBay search and didn't find many sellers that listed a picture of the exhaust side of the head, but I found a few that did and the hole for the sensor is exactly where it should be, the sensor just screws into that hole.
You can see it in this seller's picture:
RIP white Corolla
Old 05-07-2010, 06:35 PM   #5 (permalink)
RJB92ToyotaCelicaGT
View RJB92ToyotaCelicaGT's Photo Gallery
5SFE Oil pressure switch info
The oil pressure switch hole in the front of the block is threaded and the switch is very easy to remove/replace. This switch is also notorious for leaking internally between the plastic on top and the top hexagonal thin metal part. If oil is collecting on the bottom edge of this thin metal hexagonal piece, replace the switch with a new one. They're pretty cheap at any auto parts dealer. Reinstall using teflon tape wrapped two times around the threads. Check manual for torque specs if you're expecially picky but normally, the switch can be tightened down "extra-snug" and should not leak.
RJB92ToyotaCelicaGT is offline   Reply With Quote
