85 Celica GT Gear Ratios?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-05-2010, 09:28 PM   #1 (permalink)
79yoda20r's Avatar
View 79yoda20r's Photo Gallery
Hi guys i just picked up a 85 Celica Gt liftback today and was already looking into the performance aspect of the car, i plan on keeping the 22re in it, they guy that had it already has the bottom end set-up for all motor, heads done, w/ nice street/strip cam from Lc Engineering. Was wanting to find info on the 5 spd manual gear ratios as well as the rear gear ratios...i'm going to search more if any of you guys know where i can find a got decoder for Celica it would be much appreciated.
1979 Toyota Pickup 2wd 20r 3 spd Auto
1987 Toyota Pickup 2wd 22r 4 spd - Daily Driver
1991 Toyota Supra Turbo Auto-Highly Modified
1984 Toyota Celica GT Liftback 22re 5spd
79yoda20r is offline   Reply With Quote
Old 05-06-2010, 09:35 AM   #2 (permalink)
RA28 + MX73
Gameroom cash: $107620
View stepho's Photo Gallery
The '85 GT liftback has an F series diff with IRS.
Ratio is 3.417 for the manual.
You can get other ratios from 4WD shops because the F series diff was also used on some Hiluxes (aka pickup in the US) but your speedo will then need to be recalibrated.
Decoding can be done here:
http://members.iinet.net.au/~stepho/diff.htm
Basic options for the RA65 Celica are here:
http://members.iinet.net.au/~stepho/celprod.htm#cel65pr
The W58 gearbox is a good strong gearbox that is also found behind Toyotas 6 cylinder engines.
The ratios are here:
http://www.toymods.org.au/~rod/Techn...0GEARBOXES.htm
You can directly replace it with any W55/56/57/5/8/59 gearbox (but Not W50).
Some of them have the gearstick coming out at slightly different locations but you can put the rear of your old box onto the new box.
- Stepho
stepho is offline   Reply With Quote
