7afe build and turbo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-07-2010, 03:23 PM   #1 (permalink)
View perrone721's Photo Gallery
New project...Looking to rebuild the 7afe instead of swapping the head for a 4agze...im thinking it will be cheaper.
But i was looking for suggestions for the camshaft, crank, rods, etc.
or if there is a quality kit somewhere out there.
And then would i need a tranny swap?
also is a t3/t4 turbo sufficent.
any sites to research on would be awseome
perrone721 is offline   Reply With Quote
Old 05-07-2010, 05:51 PM   #2 (permalink)
Official TN Toaster
iToaster's Avatar
Gameroom cash: $349795
View iToaster's Photo Gallery
Toyota master rebuild kits are the best (and they have a price to go along with it), although not so much if you're looking to turbo your engine. I've seen some good forged 7A rods out in the depths of the internet before, but they were very expensive and I wouldn't know where to find them now. On top of those you'll need low compression pistons, which are fairly easy to find. The major weakness in this setup would be the 7A's iffy (when boosted) crankshaft, which, to my knowledge, is not sold in a stronger version.
Good choice with sticking with the stock engine, hybrid engines are always a pain. If you want, you could just swap in a 4AGZE, it's strong enough to handle ~300 hp on stock internals and it would be less of a headache building it up.
1995 Corolla DX - 7A-FE - 5 Speed - 8K1
2000 Celica GT-S - Supercharged 2ZZ-GE - 6 Speed - 3P0
RIP white Corolla
iToaster is offline   Reply With Quote
Old 05-07-2010, 09:00 PM   #3 (permalink)
Awesome thank you that helps clear things up...Ive decided to stick with the 7afe and ive found everything i need for the block but i cant find anything to build up the head for a reasonable price.
Any suggestions? thank you once again
Old 05-07-2010, 09:38 PM   #4 (permalink)
Bitter's Avatar
Gameroom cash: $560100
View Bitter's Photo Gallery
the 7A crank is pretty stout, I can't say I've heard of one breaking...rods on the other hand are the weak link and then the pistons.
Old 05-08-2010, 12:15 AM   #5 (permalink)
Official TN Toaster
iToaster's Avatar
As far as valves go, you're mostly looking at some porting and polishing at a machine shop, there's not much more available for the 7AFE head that I know about.
I've mostly heard it wasn't that great, but it's usually just been an obscure comment found through a google search... I'll have to look into that again, it's been a while.
RIP white Corolla
The Following User Says Thank You to iToaster For This Useful Post:
perrone721 (05-08-2010)
Old 05-08-2010, 12:04 PM   #6 (permalink)
alright that makes it easier..... as for transmissions do you know of any swaps and also a good performance clutch thats still relatively good for street use as well
1994 Celica
Old 05-08-2010, 12:11 PM   #7 (permalink)
also will a strut bar from a gt4 fit on my st
1994 Celica
Old 05-08-2010, 12:15 PM   #8 (permalink)
Official TN Toaster
iToaster's Avatar
The C56 is the factory manual transaxle for this generation, which is pretty easy to find. I can't say how well that would hold up to boost. As for a clutch, a stage 2 fits your description.
Also, yes, the strut bar will fit.
RIP white Corolla
Old 05-24-2010, 06:17 PM   #9 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
For 7A-FE rods, "Spool" in Australia makes them. I think the price was about $500AU when I checked into it.
There are guys in Jamaica running stock 7A-FE bottom ends with boost and others with 4A-GE heads that claim 8000 RPM constantly with no failures.
I put a 7A-FE in my Corolla GT-S after the 4A-GE crank broke. More bottom end torque, same peak HP.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
