1990 Celica GT 2.2L No spark - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-09-2010, 06:14 PM   #1 (permalink)
View griffy_jr20's Photo Gallery
i am getting a spark from the coil to the distributor but its not getting to the plugs. i have replaced the plugs, distributor (used), ditributor cap, distributor rotor , coil and the ignition module (used).
griffy_jr20 is offline   Reply With Quote
Old 05-09-2010, 10:30 PM   #2 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
Did the car just suddenly die before all this?
Also, sounds obvious but just covering the bases, is the rotor spinning when you crank the engine?
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 05-09-2010, 11:59 PM   #3 (permalink)
yes it jus suddenly died and yes the rotor is spinning.
Old 05-10-2010, 05:58 AM   #4 (permalink)
ok, was just checking the timing belt, but if it is spinning when you cank the engine then it didn't break.
Old 05-12-2010, 08:50 PM   #5 (permalink)
Gameroom cash: $139205
View 93celicaconv's Photo Gallery
What work was done to the engine in a time period before you lost spark to the plugs? It might be possible work previous done in or around the engine cause a problem that just showed up now.
A timing belt that jumped several teeth would cause this, given all that you checked and replaced already is good. If the time for the spark to happen occurs when the rotor position is retarded to the point it is almost mid-way between distributor point, the spark may not be able to bridge the gap. Have you checked your mechanical timing?
It is also possible the plug wires are shot. You didn't say that you replaced them. You can check resistance (they should have less than 25,000 ohms). However, it would be very, very unusual for all 4 of your plug wires to go bad at the exact same time.
93celicaconv is offline   Reply With Quote
