As some of you may or may not know i am in the process of putting a st182 3sge gen 2 into my st162.
The ol' 3sge only has one thermo temp sensor for the radiator fan, on the water inlet. This gen 2 3sge has two, one in the radiator (like the 5sfe st184), and one at the water outlet.
can i just use the one at the water outlet? (as i don't have a thermo temp sensor fitting or ability to fit a thermo temp sensor into my radiator) I tried to fit my original water inlet with the temp sensor, but the stud spacing is significantly different, so no go
Theres no risk or error or issues that it could cause of just using the water outlet thermo sensor from the gen 2 3sge? It will be using the original thermo fan switch from the old gen 1.
What doe everyone else usually do?
Thanks heaps and in advance,
as always, its appreciated greatly.
CHristpoher
