Originally Posted by AndrewOracle
Thanks for replying.
So is "shaken down" a diagnostic technique?
I am imagining the car on a lift and bouncing the tires around to simulate driving to see weaknesses.
pretty much, yes. I always shake the wheels side to side at 90 degrees (top/bottom and left/right) to check for anything loose. I also squeeze the tierods and sway bar links with a large pair of pliers and use a pry bar to chek the ball joints (pry between the knuckle and control arm) or load the suspension on a jack stand to check with the weight of the car that there is no play. I grab the sway bars and check that the bushings are tight and pry at all the arm bushings front and rear.
Sadly, few people are thorough like I am or where I work.
